Lumpy and sluggish when cold
(In Topic #101810)
I have a 1990 1.8 8v MK1 Cabrio GTi
When starting from cold, the idle is a bit lumpy…when you push the throttle, it sounds like its missing. Acceleration is also poor for about 5minutes until it has warmed up!
Any ideas what could be the problem?? Have changed the dizzy, rotor arm, leads, plugs and checked the timing. Have also checked for air leaked which i cant see and noticable ones. Not familiar with these engines tho so need your help.
Cheers,
what lol?? please explain, not v techincal when it comes to cars
Cheers,
Measure it just after startup and keep measuring it all the way as the car warms up to normal temperature.
You're going to need a wideband lambda or gas analyser to measure it - but it will take you straight to the problem, if there is one here.
Il try and get a hold of something to measure that or take it to a garage and get it done!
Cheers,
WUR - Resistance 22Ohms so OK
Wiring to WUR when cranking - 10V (too low??)
AAV - when cold, squeeze and revs drop, when warm no change presume thats OK.
5th injector wouldnt play a part i presume as it only operates for 10secs?
Only other thing i could think of is the temp sensor (located on pipe from head to rad with brown plug) Resistance when coolant around 30degrees is 65ohms….i dont no if this is right though?? When unplugged running gets worse!!
Any other ideas pleaseeeee…will try and get the CO2 measure ASAP
CO is much easier to measure, and this is what you want to do.
But ideally, wideband lambda (any MoT place will have both, and it would be sensible to put both probes into the exhaust, so long as there's enough venturi effect to get a reliable idle reading on the lambda.
Cheers,
Cheers,
The same advice still applies though - get the mixture looked at.
AFAIK VW coolant sensors are NTC. Very few people on here run an EFI so unlikely to find a table with temperatures and resistances on here, but on other forums and a wider search, I bet you could find a little table supplying those values no problem.
Initially - shot up to +5.3
After 1minute -0.9
After 5min -0.4
After 10min -0.4
After 15min +0.2
After 20min +0.3
Thats when the engine was up to temp and just before fans cut in.
Soooo…any ideas whats wrong then? Does it just need adjusted or does this show that somethings faulty?
Cheers,
