Loom help on engine conversion
(In Topic #136292)
Please Help
thanks Rubjonny
electronic ignition has 3 pin dizzy, but its easy to wuire in you need the TCI/ignition/spark control unit from the scuttle and the wiring loom between it and the dizzy/battery. then fit it easy!
only thign you have to do is unplug the old coil power wire, and give it a proper ignition live feed from somewhere else, or repalce the bay loom with a later one. the contact breaker coil has a resistor wire which reduces the voltage.
but you dont need to do any of that
