leaky injectors?????
(In Topic #85616)
are my injectors working properly?
also the guy who had it before me has wired the fuel pump in to ignition live ie; bypassed the relay which doesnt exist on the fuse boy i have so the pump is always on when key is turned,, is this a major issue? will pressure be to much etc,,
it always fires from cold n then dies,, and takes forever when its warm,,
regards adrian :dontknow:
Sounds like either the injectors are sticky/clogged or theres some other obstruction in the lines to them.
Fuel pump being wired continuous is a bit on the naughty side as itll continue to run even if you went shiney side down into a tree….thatd be kinda bad as itll feed a fire should you be that unlucky.
Get that sorted out asap, it could be a life saver for you.
iv had it a year n jus gettin round to sorting all the probs out but the k jet system is a pain in the arse,, the guy tht had it befor me was a total cowboy; fuel pump wired wrong,, bare wires all over n sump plug ptf tape n silconed in,, roughneck, lol,
how did you remove your injectors
Re: how did you remove your injectors
dan210276 said
just saw your blog and was wondering if you could tell me how you removed your injectors. iv tried taken them out as iv the same sort of starting problem as you . i cant seem to get em out and seem to be a nut on a nut and will just turn and turn…what am i doing wrong.. man they are fantastic cars and i love mine to bits but man they can be a pain in the bum.. good luck with yours..take care
You need to get a pair of long nose pliers around the neck of the injector, put a rag on the rocker cover and lever them out. They are just a push fit. Try spraying some wd40 onto them where they enter the head and leave overnight.
