IT WONT START AAAAAAAAAAAAAAAAAAAAH!!!
(In Topic #78665)
is the timing right ?
compression check ?
power to the coil and ignition module ?
dodgy distributor ?
www.msportcam.co.uk
Fuel Pressure
Maybe you are not getting enough pressure to the injection system and the injectors cannot open at all. Bought another new fuel pump and it ran fine again, all this was down to water in tank from the dreaded filler neck rust problem. There is a section in the Haynes manual about injection system that describes the use of pressure guage.
Check to see weather any fuel is returning to the tank, by releasing unoin on side of fuel destributor on the return line (carefuel fuel maybe under high pressure extreme caution). Section in haynes manual of quantity that should return to the tank. All the time fuel pump is running (engine not running, short fuel relay see prowlers injector test) there should always be a large quantity of fuel returning to the tank, if fuel pump runs but there is no flow of fuel back to tank this means high pressure circiut has not enough pressure to open the injectors. Possible cause worn pump again, blocked fuel filter, blocked filter in fuel tank (view able through fuel gauge sender mounting, under back seat), low pump voltage (should be no more than 1volt less than the voltage measured at the battery).
You could try borrowing a pump see if it works. A long shot but worth doing is changing fuel filter (could be blocked). Do injectors test (search prowlers injection test in google).
Link to video of how the system works you can hear the amount of pressure is require to open injectors.
http://www.taunusfinland.com/tiedostot/ford/K-Jetronic/kjetvideo.mpg
Good Luck
Cussco
Re: Fuel Pressure
Good Luck
Cussco
…Injector Test
…that movie is brilliant - you can really hear those injectors……
Video
Prowler you shoud link it to your injection test PDF, helped me relise how the stuff all works.
Cussco
mick-d- said
i dont no how i fixed her but somewhere in the middle of changing from the fuel lift all the way to the injectors i lost more petrol than i thought so when i changed the whole fuel sys i put in more petrol and away the girl went. im well chuffed but im a bit annoyed that i dont actually know what was the matter with it.
…welcome to the world of Mk1's
cussco said
Prowler you shoud link it to your injection test PDF…….
Cussco
…done….version 3b online now, with link to the vid hosted on my .info site, and to the original…..
