Is my oil cooler radiator working?
(In Topic #72778)
Not sure if it has a built in thermostat which may explain cold pipes?
Peter.
1980 1600 GTI, daily driver.
From what I could see, the stat will always bypass a small amout of oil until or if the temp reaches 110, then it opens fully. Hence the reason for the pipes being cold.
New stats are available from VW too at around 43 quid + vat.
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
If thats the case if I fit a stat that kicks in at a lower temp my engine will run cooler?
My engine performs better when cold than hot. When my engine temp. reaches in excess of 100 degrees the engine will give a tingling sound on acceleration.
my oil temp is always between say 83 and 93 normally, rising to around 100 when giving it some!
The tingling noise you can hear lhasa could be pinking under acceleration, mine does it , especially on hot days.
What you could do though is fit a mk2 set up aswell, so you can have the oil warm up quicker using the matrix on the filter and should help temp the temp low too.
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
I wouldn't recommend fitting a lower temp stat because the oil temp should be atleast 80 degrees to work properly. Using a lower rated stat will only keep the temp barely at 80.
Wonder if mine has wrong stat fitted? On average doesn't get much above 85-86C unless very hot weather - only occasionally passes 100C. Today driving round town didn't get above 83C. I checked oil cooler pipes when I got home - they were warm?
1983 1100 C
1983 1100 C
Is the tingling noise from the tappets hitting the piston? couldn't figure it out myself.
Crazy - tried that and got a big drop in performance, so I put it back to where it was.
My Mk1 pinks very slightly under light ish acceleration for a moment, but if I either ease off or acellerate harder the pinking disappears. It also does it on hot days too. I think mine does it because I have got a 16V warm up reg mod done.
This is where a K star or a V Sam comes in as the ign timing can be mapped for fuelling etc.
Anyone else elaborate on this…
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
