is my gfi over heating
(In Topic #103111)
1987 Golf Clipper Karmen Cabriolet - lots of work to do yet!
If I were you I'd sort the leak, flush the coolant and refill with the correct mixture ratio and see how she goes.
If you can check the temp difference between the top rad hose and the bottom one, a good 10c is ideal to show it's cooling properly.
Lastly check the pump pushing water back tonthe expanion tank at a nice steady pace.
T
Stu
WelshBlu said
the pump to the expansion tank isn't constant, more of a stop start motion. Does this sound like the pump's on it's way?
Make sure you check it while revving the engine to at least 2000rpm. Should be a steady stream of water - if it spits then that is air bubbles being released from the system. Might get this for 5 mins or so but should eventually stop.
