Intermittent cutting out?
(In Topic #119426)
Im running a 1.8 16v kr conversion on k-jet.
Just recently it's been running and starting fine, but every now and then would lose power when moving and either forcing me to pull over or the majority of the time it happens at speed and just bursts back to life like it's been jump started.
The times where i've had to pull over, after a couple of minutes of trying to re-start, she just suddenly kicks in and everything is fine again.
So far i've changed the:
dizzy cap
rotor arm
ht leads
fuel filter
but these haven't had any affect.
I suspect it's more the fuel side of things the way it juct loses power and therefore would changing the fuel pump be the most logical next move?
Any advice would be great
Failing that it might be fuel starvation due to rubbish in the fuel lines - does it kangaroo around when the pedal is pressed down but stops if you let off it?
rubjonny- yeah it does include the isv, i'll check it out.
Thanks again
I've been fiddling around with it this morning, i've just ordered a new relay just so i can eliminate it, buy when i turn the key i can still hear the pump prime and the relay click, it starts for less than a second then dies, so i'm guessing the relay is actually fine?
it should be round the back of the airbox, it has 1 pipe to the airbox and the other to the inlet pipework somewhere
