Inlet Gasket Help Please
(In Topic #74840)
Problem it has the 4 holes for the inlets and then an extra one just above. This is in between the first and second one as if you were looking at the engine going from right to left.
After a good look there is actually the hole on the head which I presume the gasket goes around but my manifold doesn't have this on.
Gasket number 026 129 717 D
Manifold number is 049133223
Either I've got the worng manifold on the car some how, this hole don't matter or its the wrong gasket. Don't want to fit this one as I presume I'll get a bit of leak. Let me know please wanted this sorted the weekend so I can move on to the sump oil leak.
Mines the same as in this picture, but the gasket has a bit coming up as already explained.
Then got to work out why I've still got a slight oil leak from the cam end on the rocker, and also need to sort out the oil coming from the sump gasket that I must have over tightened to stop the leak in the first place.
Cheers crazy
