Injectors
Injectors
Hi,
I'm after a bit of info.
Will Mk2 Injectors fit the Mk1 and if so, will they run ok?
They look physically the same, but they seem to have an extra rubber o ring near the tip, what is this?
They're on ebay, the description says they'll fit, but i wanted conformation from people in the know (that's you)
Hope you can help
I've used Mk2 injectors with the little 'hat' as I have what appears to be the later seats with the plastic lower shroud…….
see Injector Test
2000 (Mar) Passat Sport Estate 1.9 TDI (ATJ) 5 speed automatic with Tiptronic - TUG 2 (Remap and cruise control by CCC)
