injection pump
(In Topic #72497)
injection pump
Strange thing is this is not the first time this is the 2nd pump to fail this way and i wonder how long the 3rd will last?
Any ideas what could cause this?
i'm going to by pass the lot and put a switch in a ignition live and a feed to the pump and see what happens a cant really afford to destroy another pump.
also an inline filter before the pump should stop any crap getting in the pump just in case.
Then the pump died (it looked a relatively new replacement itself) and then a second brand new one did the same. :x I had had the tank off and swilled out as much debris as possible during the rebuild but there was still some crud in there. Sooooo?. before fitting the 3rd replacement I lashed up a large inline filter in-between the tank and pump. This summer I removed the filter and replaced it with the original rubber pipe as I couldn?t find another similar filter. I guess after 15000 miles it had filtered out all the crud anyway.
