Ignition timing question - 1800 DX K-Jet
(In Topic #116489)
1. Does the 'dash' on the flywheel need to be 'in the middle' of the viewing hole?
2. Do I need to disconnect the distributor vacuum pipe?
3. What revs should I use?
Rene
mine's a green 1.8 GTI '83
Re: Ignition timing question - 1800 DX K-Jet
1. First if you get down a little lower and look up at the top edge of the "viewing hole" you should see a pointer facing down towards the flywheel (it's cast into the transmission case). Next are the flywheel markings. There is a "dot" (cast into the flywheel) which is top dead center (TDC). About 12mm from that dot will be a notch machined into the flywheel. It looks like someone used a triangle file and made a mark along the ridge of the flywheel. That is the 6 degree mark. The TDC mark is used to set the motor up, i.e. timing belt, and the notch is the factory ignition timing position.
2. No, for your motor leave it attached.
3. Idle, that should be around 900RPM (don't have a manual handy).
So… John would I -
1. Remove the hose from the dizzy and plug, or
2. Remove the hose from the manifold and plug, or
3. Plug both the dizzy and the manifold?
Makes sense to me your suggestion, on previous cars I've always needed to remove the vacuum pipe. What does Grimyfingers reckon?!
R
haynes and the ElsaWin repair manual VW mechanics use both agree that this is the way to do it
Not that it matters, but yes, on the DX the vacuum is removed. I did say somewhere that I didn't have a manual handy. Best to always check a manual before doing any work and not take anything printed or spoken as Gospel.
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
