idling problem -engine stalls
(In Topic #85991)
when at this level and below -here a cracking nose in the injection/air intake-sounds like the buttefly valves are being wipped back and forwards!
i guess this is misfiring but not sure?found that the bolts holding the aluminium intake housing were lose so i guess allowing air in, tightened these but tha problem seems worse!
anyone any ideas?
Timing
Fueling
Aux Air Valve
Warm Up Regulator
Have you got a copy of the Haynes manual? It has good tests for some of the above…
woZa said
Checklist…
Timing
Fueling
Aux Air Valve
Warm Up Regulator
will have a look at these - i suspect fuel starvation -started to strip down but joints on fuel acc. all rusted up - dont fancy ,messing too much with all that fuel around!,timing ok.
will check the 2 injection components. yes have a well used ,oily copy!
do you think the gasget on the al. housing may have beeen damaged when the bolts were lose-could this cause the symptons if air is getting in?
Have you replaced the fuel filter recently? Some fuel pumps have a small mesh located at the pump inlet. If there is any rubbish in the tank then this could be blocked.
Have a search for Prowlers Injector Test and see if the flow rate is up to spec also.
nig said
cant find any info on the prowler test -any info?
http://www.vwgolfmk1.o…5&highlight=injector+test
Search is your friend! :wink:
the problem was the loose housing bolts and a blown housing gasket causing an air leak.needed to take head off to access ,but now all refitted and bolts to correct torque.
thanks to all who advised!
