Idling mystery?
(In Topic #120311)
Idling mystery?
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1 piston rings
2 valve seats
3 valve clearances, this being most likely as you say it makes good power although if these were at fault it would make better power once shimmed correctly
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
The larger overlap cams do indeed start to cause problems with k-jet, 288 should be fine although I think 295 onwards would probably be a bit undriveable as it basically forces a bit of gas back up the induction ports at lower gas speeds which can cause the metering head to flutter at lower revs, obviously the best way of smoothing out the airflow on the bigger cams would have to be a turbo or super charger
I am quite sure that there is no vacuum leak as I have listened to every join in the vacuum loop including the inlet manifold with a thin rubber pipe and everything seems quiet. The distributor timing is correct as well as the cam timing, and the co's are correct. The fuel pump measures the correct pressure, and the injectors have a clean spray. Is there perhaps something else that I am missing? :dontknow:
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
I second recommending you recheck compression :-)
When you say that the idle adjustment screw makes no difference, does it actually increase the revs? if not then does opening the throttle slightly with the vacuum pipe off and the hole on the throttle body blocked make it idle nicely? if that works then you need to clean the idle bypass on your throttle body, probably gunked up.
Does the fast idle work properly from cold?
Thanks for the advice so far guys
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
