Idling issues
(In Topic #110568)
Idling issues
I have swapped over the aux air valve from my other GTi, as well as all the vacuum hoses and one way valves but it made no difference. The Aux air valve does receive 12v as long as the fuel pump runs, and the cold start valve tests o.k. I have also sprayed with carb cleaner all over the inlet manifold and induction system, but cannot notice any increase in idling. At the moment the idling screw is all the way out, and the idling should be way high. Is there something that I am missing??
Any help would be great… Thanks
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1983 GTi Mk1 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
1984 GTi Mk1 2.2lt
1991 Jetta CLi 1.8
1989 Jetta CLi 16v
2001 Polo 1.8
T
1. Timing
2. Mixture
3. Idle speed
because the first 2 affect the idle speed! Needless to say, to adjust them within spec, you need to be able to measure them accurately.
