Idle speed drops
(In Topic #117223)
Idle speed drops
The car idles fine at around 1000 rpm hot/cold but when lights/ fan/ anyting is switched on the revs dip. has fairly new alternator and battery but is becoming a problem in the colder darker weather. Any ideas what to do would be great.
You can add one of the idle stab systems VW has ysed over the years but that would require some extra cost, not a lot, and adding things in the engine bay, not original and adds to clutter if that is a problem. You can also just turn the idle up a bit during the Winter and back down when it warms back up.
A second system uses a solenoid type air valev, two for air conditioned cars, a relay and again some wiring and tubing. This system does not stabilize the idle as well but does work OK. There are many engines which use this one, mostly early CIS models and the parts should be cheaper and easy to locate.
