Idle problem finally solved & a cam belt question
(In Topic #113815)
Stock cam (i think)
Cam that was in my car
Anyway I have swapped the cam now and I am not 100% sure about the belt tension, I was very careful when I took the cam out, engine was at TDC and I marked the belt, I have made sure all the timing marks line up and pushed the tensioner as tight as it will go before tightening the nut. The trouble i have is that this is only tighening the one side and the other side of the belt looks too loose (see pics) it does only twist about 90 degrees though.
Question is does this look ok and how are you supposed to adjust the tensioner, the one in the Haynes manual shows a 27mm nut for a spanner as well as the slackener nut ???
BTW, my engine is the original 1979 EG series 1.6 GTI
Any help much appreciated, I am dying to get it back together and see if it finally runs right.
Kev
Old cam seems to be a race version and from the looks of it a worn out cam also. It is not normal to have sharp edges between the lobe and the side of the lobe. Might want to check the shims for wear too.
All the shims were changed while I was troubleshooting (didn't know the cam was incorrect at that point) not only was the cam wrong the gaps were also miles out.
You've got the method for checking the tension of the belt about right, though.
it should be spun clockwise when setting the tension, you'll soon know its wrong as the tensioner will fowl the inner belt cover!
Lesson is I guess don't ever take it for granted that the correct part has been fitted previously.
