Identification of cylinder head
(In Topic #94098)
Can any one confirm this is a mk1 cylinder head or is there another way of making a positive identification from the head alone.???
cheers ryk :?
Update with photos
Hopefully this post will show a photo image which may assist with identification. If any further views are required please let me know. I have an oppotunity to obtain a second hand head and obviously I would like to get the right one.
Help needed to unravel this problem
I thought this would be easy without having to expand.
Let me tell you a story - are you sitting comfortably??
Back in the late 70s and early 80s a company called 'Pettar' brought a large number of the diesel injected engine ( non turbo ) from vw.
These were converted for marine use by fitting their own exhaust system and fitting a marine gearbox.
Needless to say I own one of these boats with this engine of which the camshaft snapped and shattered the head at the no 1 valve cap
I have been informed that I could replace the engine with anything from 1982 - 1992 as the mating faces of the exhaust and gearbox were the same. Therefore I got a 1983 engine from a breaker fitted it and within 2hrs the big end went!!! not happy :cry:
I then thought just change the heads :wink:
So I fitted the old block to the boat, cleaned the newly obtained head taken off the engine that had just died and went to fit it. :?
It was when I aligned the head gasket did I notice the difference ops:
The new head had extra ports
compared with the old head
Being a boat engine the original block will not have encountered much heavy workload nor have run as many hours, there fore it would be benifitial if i could fit another head to the old engine block. If only I knew what engine I had!!
Therefore I have one good head, one good block, neither are compatable and I do not know what model of engine is which.
So I ask you if you can help me with this puzzle for if I can identify which is which I would hope to buy the right bit therefore not waste any more money!!!
PLEASE!!!!
