I can't keep it up!!
(In Topic #121695)
Everytime I use the car it idles more slowly than before. I turn the Idle screw to speed it up, but the next time I use it, the idle rev's are low again.
Probable cause please anyone? 1982 GTI (1.6).
Cheers,
Actually, I've got the same ('82 1600 GTI) and started to experience the same problem over the last week, now idling around 3-400rpm! doesn't stall though
sorry, I'm of no help! but hopefully someone will have an idea to sort both our cars
Secondly, sometimes variable idle is caused by the mixture being poorly set, normally too rich but can be too lean. This makes ignition more difficult and ignition misses occur, which obviously will lower idle speed since there is no power on the power stroke but the other 3 still do the same.
In fact, poor quality ignition can cause idle issues in general anyhow.
I think the mixture keeps becoming too lean. I've had it professionally set twice in the past 6 months, but I can't afford to keep taking it to the garage and I don't have the skills/tools to do it myself!
Dodgy metering head?
