ht leads
(In Topic #77406)
ht leads
hi, i'm a bit confused as to which ht leads to get for my standard 1983 1.8 8v gti. I've been quoted anything from ?20 to over ?100. Any help would be appreciated. cheers!!
Cheers! where can i get a set of these from?????????
You can get Quantam leads at VW - they are fine too. Think they're about ?26ish :dontknow: cant remember.
Don't get the ones from Eurocarparts for about ?17, they only last just over a year before the rubber cracks/perishes and they brake down electrically.
Its worth spending out a bit in the first place instead of paying twice!
just go to gsf and get the leads they recommend
think they're hella and come in at ?23.50
GSF also sell dodgy ?17 ones made by Beru. Had excatly the same problem as Ross. Leads hardened up and failed after about 14 months . Paid ?26 for OEM spec set from local parts factor.
1983 1100 C
1983 1100 C
Hi,
I'm also in the market for a set of HT leads for my 1.8GTi (DX). My local Halfords no longer stock the Bosch parts.
Can anyone confirm that the GSF part for the decent quality items is "92630A IGNITION LEAD SET-BQ G1 1.5 - 1.8 >7/83 23.50"
Just want to make sure as they don't list any others on their website but there is mention of a good and bad set from GSF in this thread.
Cheers!
Cheers!
Not sure mate. You might be better off going VW as at least you know they should be good. I just had a problem with another set of leads on my sportline. They looked new too, but didn't have a make on them.
You could call them and ask the make. Someone mentioned Hella? would have thought they should be ok if they are?
Cheers, I'll order them from my local VW place just to be on the safe side.
Make sure you ask for Quantum leads at VW, should be about ?26 for the set. VW also sell obsecenely expensive VW branded set for about ?110 8O
1983 1100 C
1983 1100 C
