How much oil?
(In Topic #84995)
How much oil?
Stupid question and i should know ops: (cant find my haynes at the mo) how much oil does a mk1 DX engine take on an oil and filter change? so long since i done one! about 8 years ago :roll: from memory i think it was 4 1/2 litres? is this right? cheers for any help
Guess nobody on here knows then? :dontknow: well its 4 litres if you drain and change filter, just done it
Strange - should be 3 litres without filter, 3.5 litres with :dontknow:
1983 1100 C
1983 1100 C
i think it's about 3.5-4 litres with filter. i know i used to use mobile 1 in my old mk1 and they only came in 4l tubs. it pretty much took that, but defo no more
Maybe you need to check your oil then? it definately takes 4 litres! maybe slightly different on a conventional oil cooler Gti? but mine has the water bath type cooler 4 litres is bang on the level mk of the dipstick, but thanks for the reply
hope your dipstick thingy hasn't worked its way up the shaft. worth checking just in case. more likely the 3l capacty one is broken though
yeah good point, its got a new orange doofer tube thingy on and i checked it and it is pushed right down on the tube properly so i guess it must be reading right? runs nicer now anyway with fresh oil and filter and plugs
Just checked the VW mk1 handbook and Haynes manual and they state 3.0 litres without filter and 3.5 with for big blocks. I have got an air oil cooler, but all mk1 GTIs did, is yours a cabby? The big block engines went up to 3.5/4 litre in 85/86 when the hydraulic head came in (also bigger sump?), is it definetly a DX engine :dontknow:
1983 1100 C
1983 1100 C
yep its a DX and its a sportline cabriolet 1992
May be the water fed oil cooler, or a diffrence in design of the DX after 1983 - they didn't give it a hydrualic head did they?
1983 1100 C
1983 1100 C
it has got hydraulic tappets and the waterbath oil cooler and the bigger sump, maybe thats why the increased capacity?
Web Team
thats why i just filled it to level on the dipstick!! no info was available, 4 litres takes it bang on the level mark, on mine anyway! they all use a bit so i always keep an eye on it every few days, been out blatting in it with the roof down all day today 8) got some jealous/strange looks too! new Alpine head unit does the buisness with all the upgraded speakers that were already in it, sounds nice and is still audible even at speed :wink:
Today in 1.8 cabby injection model I filled to 4litres with oil using dip stick.. funny as like before Haynes states bit less.
On the drive
Myvalver 89 GTi Grey mk2 16v
