how do i change my head gasket ?
(In Topic #74890)
Member 125 - 2005
As Crazyquiff says, get a Haynes Manual or Poor Richard's Rabbit Book (used - from Amazon - highly recommended) before you even attempt this job…its not at all difficult but there's a few pitfalls along the way.
The first question has to be, however, "why are you doing this???". If its obviously leaking water from the head then fair enough….has it been "cooked" and warped as a result ? then it will need skimming. If it is burning a lot of oil due to kn*ckered bores/broken piston rings then changng the head gasket won't help. If it puts out a lot of oil smoke after a period of coasting downhill with the throttle closed followed by flooring the loud pedal, then the valve guide oil seals need replacing…better done with the head off then replace the gasket. Muck out the carbon from ports/valves and re-seat the valves anyway while its off the car. You will probably need to replace the tappet shims anyway….and the timing belt / idler pulley..etc …as it recommends in the manual.
Good luck
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
Member 125 - 2005
A VW Golf leak oil dont be silly it's just marking its territory!!!
mk1jim said
cheers for the replys. reason i think it's the head gasket is because it has started using water and my oil has turned to cream.
Sounds like a head gasket to me. Apologies for stating the obvious, but don't run the car too much with oil like that if you can avoid it - you may end up damaging it quite severely.
How many miles has it done, out of curiosity?
Member 125 - 2005
