High oil pressure
(In Topic #73396)
High oil pressure
Does the light / buzzer go off straight away or after 2000rpm or randomly? Do you know the replacement clocks are OK or from ebay with no history?????
:dontknow:
it's true, i don't know for sure if the second hand clocks aren't also duff, assuming they are, can i buy a replacement circuit brand new still??
i'm dubious about it being an electrical prob because when i first bought the car, the buzzer was intermitant, and on the motorway non existant…gradually the buzzer has come on quicker and stayed on longer until now where the damn thing is on all the time…..would an electrical fault deteriorate gradually like that or is it more likely to just suddenly go from working to not working??
Again as already mentioned I?d check all the earths, braid+brown wire on cam cover, brown wires next to fuse box etc.
If its any consolation mine goes off sometimes, usually when the car has been baking in bright sun all day. Usually just the light but sometime the buzzer. Normally a wrap on the cluster with knuckles makes it go away. This proves to me mine is an electrical fault in the cluster. I have VDO gauges to reassure me that the pressure is OK.
and I thought it was just me that used that to "solve" problems with the mfa etc etc
Quality German engineering…….. fixed by good ol' British techniques
Have you diconnected th wires from the oil switches with the engine running to see what happens with the buzzer and light (sorry if this has already been suggested )
the second hand clocks i bought have just been in bits on my tabel…. i must be thick but i cannot locate any "L" shaped circuit…..anyone got pretty pictures so i know what i'm looking for???
Not sure about the L-Board it?s just what I read. Anyone got EKTA they could look at?
I find your info about the problem getting worse and worse as time went on to be very familiar - this is how mine was, until it would happen all the time the ignition was on (once it had been triggered the first time by going over 2000rpm). I think that this may be caused by the drying-up on some of the soldered joints on the board - see below.
I sorted the problem by changing to a km/h instrument unit (Ireland changed to metric speed limits last Jan), but when I also changed my Audi 80 clocks to a km/h one from an Italian breakers (the Italian word for a car breakers is great! - Autodemolizioni), I had a big problem with intermittent readings from the fuel gauge, and the solution was to take out the printed circuit board and to re-solder each joint, adding about 10% extra solder as I went. The result was that the whole unit seems to work much better with slightly better "wake-times" for both the fuel and temp gauges after start-up, and no more heart-attack moments as I glance down to see the fuel gauge near the bottom of the orange area all of a sudden!
I would try re-soldering the L-shaped circuit in the Mk1 to see if that helps. PS: Be careful not to accidentally join together two or more of the legs on the microprocessor on the circuit board - the legs are really close together, so don't add any extra solder here.
will post the results
then it won't happen for a week.
it is so annoying, as everytime it happens i stop the car………..panic for 5 mins………………… drive off, it happens again……………. stop, panic, drive off and it does'nt happen again for days
at least it has character and is'nt a boring ford. lol
Mandy
:cheer:
