high idle --- my solution
(In Topic #95092)
been having problems with high idle at normal running temp at about 12 to 1300 rpm after further investigation noticed that the pipe which runs from the back of the aux air valve to the metal pipe which runs along the bulkhead had collapsed, so i took it off renewed it and all is sorted just thought it may help someone with the same symtoms.
I have the same issue - car idling at 1200-1300 when hot.
