help wont run!!!!
(In Topic #144022)
help wont run!!!!
I have bypassed to fuel pump relay to check to see if this was at fault, and it ran pretty much without fault. I have changed the pump relay for a brand new one which now primes the pump unlike the old one. The car started first time after and ran for about half a mile then boom, back to the jolting and kangerooing down the road until eventually cutting out. It would then not start for a while and when it did run for about 30 secs it peatterd out and wouldn't start again.
I managed to get it running the other day for about a minute or so but then it started to run rough and eventually cut out. the fuel pump runs fine even when the car cuts out and the spark is fine.
I have noticed that there is a rumbling noise from the metering head just as the car starts to play up almost like there is a blockage, i was just wondering if anyone had any ideas??
Also is there a separate filter in the metering head itself as someone once told me there is a small gause type one on the main feed pipe to the head? any advice gratefully received.
matt
poor running
Any advice again gratefully received as i want to get it up and running for the shows!!!
Many thanks again John.
Matt.
have a look inside the tank as per:
The Mk1 Golf Owners Club
then i would look at the main pump perhaps, check the fuel reservoir under the car too, if its running low then that would suggest the lift pump is struggling to keep up.
though you might want to look at the ignition system too before you spend too much money, the fuel pump relay needs a rev counter signal from the coil so if the missfire is coming from the ignition system it can effect the fuel pump relay and so in turn the fuel pump. look at your dizzy wires, the dizzy cap, arm and leads to ensure all is well there. if in doubt renew it all with bits from here:
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
Any more advice gratefully received.
Many thanks Matt
it may be there is an electrical issue, i would look at the fusebox next. drop it off the hangers and inspect it closely for water damage, also pull each relay out and check the pins for corrosion. look at all the fuses too in particular the fuel pump one
Its driving me mad now as i have very little time to dedicate to the car and i am reluctantaly thinking i may have to take it to a garage!! Do you or anyone know of any decent vw specialists in the tamworth/ staffordshire area?
or failing this anymore ideas????
Many thanks again
matt
I do also remember some time ago that i had similar running problems but this time the car would just jerks and kangeroo at lower revs. I found that the no5 fuse for the fuel pump had got vey hot and was causing a poor contact. The car ran fine after replacing the fuse, i do sometimes think that the issue may be fuel pump related as it only happens under load, it will rev freely and run very well until driven fairly hard.
Any more ideas or experiances gratefully received :wink:
Im therefore thinking about changing the main fuel pump and the lift pump to?
Has anyone had similar problems or could they advise me if this is a good cause of action to be taken?
many thanks again all for the Advice
if all is well with a bypassed relay perhaps its the relay itself that is bad, or the fuseboard
The problem now seems to be solved!!!
I have now done over 80 miles trouble free, so happy days.
Many thanks to all you guys for the help and advice.
I hope this helps other people with the same problem
Thanks matt.
Thanks again John
