HELP - Water pipe query
(In Topic #134001)
Does anybody know where I can source the small U shaped water hose at the back of the main metal water pipe that runs around the engine block. It is obselete from VW and only seem to be able to source it as part of a set. Any help would be appreciated.
Al
I had a struggle getting a full set of standard coolant pipes for my mk1 , but you can now get the full standard set including the bit your looking for from "vhw20" link on the left.
baz
I think I might have a solution though. I might end up using a piece of copper pipe bent through 180 degrees and then jubilee clip a straight section of hose onto it. I dont see why that would not work.
cheers for your post
