Help required in fitting new engine
(In Topic #129240)
I recently bought from the local auction a Mk1 Golf Gti cabriolet on an F reg '88 for a project. On inspection it was clear to see that the engine within the car was not a 1.8 injection but a 1.8 piersberg carb. The chassis number, log book and further checks confirm that the car should be a 1.8 Gti.
The car runs but it is not smooth and idles erraticqally and cuts out on occasions. I am considering replacing the carb engine with an injection engine to make the car as it should be. I have contacted the previous owner to find out if they can shed any light on the change but to date have received no reply.
I have picked up a complete engine and gearbox with all auxcillaries of ebay which I hope to use all being well. This engine is from a 1990 1.8 gti which i was told was a Digifant injection.
I dont have any form of ecu unit to control the injection system with the engine I have bought and I cant seem to find anything in place within the the engine bay of the car either.
Any advice in regards changing the engine or words of wisdom on my situation would be appreciated.
many thanks
Chris
Life Member
Further to my last
It was orginally a gti and for some unkown reason it has been converted to the carb.
Since posting my last question I have made two discoveries. First being a small black box under the scuttle panel on the passenger side of my car which im guessing is the control unit. Secondly I have come across a K-jetronic engine and gearbox complete with air flow meter box and hoses/metal pipes.
The ad is local and also states that the vehicle is being broken and other parts available.
Would this K-jetronic engine be a better option than the Digifant one I have and if so what other parts is it worth having to complete the engine job?
Any replies would be appreciated. Cheers
If most of the stuff is there, then buying and transferring a K-Jet motor into it shouldn't be too hard. If some items are missing, then you'll need to budget for that, a good place is the classifieds here for bits & bobs. I'm sure funkstar can help you out with parts.
However your probably doing exactly what I would do and go down the mechanical fuel injection route!
I had someone fit a K jet injection engine in to my clipper cab (was a carb engine), but that developed a knocking noise and fairly terminal oil leak. So Ive taken that out and am in the middle of a 20vt engine swap.
So if you need any parts off the engine let me know, I've also got a K&N panel filter that was freeshly washed and oiled just before I took the engine out if your interested?
06 Audi A3 (Wifes daily)
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=61457
2e2 is an awesome carb, if its working. can be a big if though! unfortunatly spares not so easy to find in scrappies nowadays, not liek back in 2003 when i was fixing mine
