HELP!! My car wont work
(In Topic #97439)
I have a VW Golf MK1 and can't get it to start. It cut out on me two weeks ago and hasn't started since. I have had the car in at two garages (one of which was a vw specialist) and they have both said they can't figure out what's wrong.
The car starts but does not keep running, I have had the immobiliser disconnected so it's not that cutting it out. It has full pressure (although not 100% whether there is full pressure to the injectors).
Have changed the fuel metering head and the pressure regulator valve with no luck.
I really am stuck on what this could be, if anyone has had a similar problem then please let me know. I'm pulling my hair out!!!
:dontknow:
muck in the fuel tank, runs ok, then all of a sudden
cut out, left it a bit, and it ran again.
I ended up replacing the tank (you can flush them out)
replace fuel filter, replaced pump , then realy as I
burnt that out as well. I also replaced the injectors
as a precaution.
It may be something as simple as a dodgy earth though?
If it starts & runs, its either something getting hot,
and failing, Coil, dizzy cap (cracked), or fuel related, im
not a mechanic by the way, I just figured mine out by trial
and error, which is very frustrating!, but I had tried everything
by the time I got to the fuel side of things, because fuel
was always reaching the cylinders I overlooked it :roll:
Anyway best of luck :wink:
dibbler
