HELP-MISSFIRE (KANGAROO) BETWEEN 1000-3000 RPM
(In Topic #74943)
so the story so far is the whole fuel metering unit has been changed which was well shagged any way, just fitted a new filter now just gonna get some new injectors and fingers crossed all should be back to normal. seems funny that i've owned this car for 2 years trouble free now these annoying little problems but then again it's always good to have a little tinkering in the bay.
oh does anyone know if you can get larger injectors to fit or does it just have to be direct replacement? :dance:
Hello me…….
Fit the same as came out with new seals you will not notice any difference using different injectors unless you have modified your engine . I tried this using Porsche bits and gave up . GSF are cheapest at about ?25.00 each , change the fuel filter while you at it so no crud ruins the new injectors . Run some fuel system cleaner every 4th tank and it should keep it sweet . How is the fuel filler neck is it rust free as this may be adding to the problem ..
Cheers……….
Campaign Mk 1 Black
16v Mk2 Red (decsd )
