HELP ME!! STARTING PROBS WIV MK1 GTi 1.6 82
(In Topic #94943)
my car has been stored away in a garage for the last 10 years, have got to the stage where the car will turn over, have checked spark there is a spark but it still wont start.
any ideas???
put new spark plugs, lead, dizzy cap , rota arm and put petrol in.
but it still doesnt want to start. ive ordered a new coil which is coming on mon to see if that helps as it doesnt look in condition.
Can you hear the fuel pump spin, either with the key turned to the first position, or when you turn the engine over? Is there voltage to it? If the answer to these is yes, then it's most likely to be a blockage in the system.
To fault find, I bridged the connections on the fusebox with a switch so I could turn the pump on and off without the engine turning over, then started at the front of the system (injectors), and unscrewed each component, working my way back to the tank. Each time I removed a component I switched the pump on and examined the fuel flow. Eventually I found the blockage was in the tank itself.
HTH
Rich
novocaine said
can you see fuel passing though the inline filter? or whip the air box off and look down the carb to see if fuel is getting in.
not on a gti
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
