Help help mot tomorrow
(In Topic #122589)
Hi folks is there a man fuse or relay for the ignition system? the car was runing fine but know have no spark at the plug or ht lead is there anyway of testing the coil and igniton amp on the bulk head. on the dizzy there is a multi plug that goes to the ingniton amp could it be that? any help would be great… mot tomorrow and the car wont go
or the order to start checking things (the only thing i can think of i have had the clocks out and when i put the multiplug back in there was a slight short i think it was the red wire with a black stripe(old solder joint))
First thing to do is check that you have 12v at the coil when the ignition is on, if you do then there is likely a problem with the amp/dizzy or wiring between
hi there is 12v on the spade terminals on the coil... is ther anyway of testing the amp? were does the wireing go toin the dizzy?
