Help!!!!!!!!!firing on 2 cylinders
(In Topic #72489)
Are you 100% sure that you're getting both fuel and a spark? - unless you've got valves which are bent or stuck open, or a hole in the pistons 8O , you must be missing one or the other.
Life Member
Mk1's nothing but trouble :cry:
lhasa said
Cheers.
ALL cars are nothing but trouble, but at least Mk1's are a joy to own and drive, when they are going well…
PS: Did anything notable happen to bring this fault on? - accidental over-revving, new timing belt, filled up at different filling station than usual, etc?
Any clues?
Remove the spark plugs, and get an assistant to turn the engine over with a 19mm socket on the crank pulley nut, while you shine a torch into each spark-plug hole to see the edges of the valves move in and out as they should. If any of them are dropped (stuck open) or bent, you should be able to see this, especially when compared against cylinders 3 & 4, which are working fine.
Not that I think it's a good idea…
Heh, this should be in engines. Problem with putting it here is we'll never find it in a years time if someone comes up with something useful to say.
On second thoughts…
Peter.
1980 1600 GTI, daily driver.
lhasa said
Good idea type17, is it possible to push up the valve with a rod from the spark plug hole, if not could I get away with straightening the valve once stripped?
There'd be no point in pushing the valve back up, if it has dropped, because this means that it has slipped out of its collets, and so the tappet bucket needs to be removed too, for it all to be put back together (replacing any damaged bits too).
Also, if the valve is bent, and you push it back up, you'll damage the (soft, brass) guide in the head, which might not be damaged already.
If any valves are bent, you won't be able to straighten them satisfactorily - replacement is the only option :cry:
Anyone knows of recnditioned engines.
Cheers all.
Did you compression check with the starter?
Need to pop the head off and have a look.
Might be rings, holed pistons, valves not fully seating, burnt valves, broken con rods……
Now looking for a reconditioned engine, anyone know where to get a good recon?
Not sure about having the engine rebuilt by a local company. Again, regularly hear of people who have had their engine reconditioned by a local engine builders only to find themselves having problems with it several months down the road. Seems to be a high level of variance in the standard of local engine specialist.
One person who I would thought would could be good to approach about a rebuild is Ian at Wagenwheels. When it comes to MK1s and GTIs, Ian knows his stuff an more importantly is an enthusiatsts as well. He reckend I'd be looking at around ?1000 for a full engine rebuild.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
The VEGE engine looks ok, does the price include vat?
After 3+ years and 15,000 miles it seems to still be running OK.
I think the bill came to @?600-700 including a new conrod, pistons, pressing in some engine mounts and cleaning the inlet manifold from about ? tonne of congealed oil.
