Head Gasket PLEASE HELP!!
(In Topic #120401)
water ther is no oil in the water though.
how easy is it to do? i have only ever changed the clutch and done a few other little bits
are there any guides on how to change the head gasket? what
tools and bits do i need? and anything else i should do while the
head is off?
thanks
kai
MK1 Golf GTI 8v lhasa green
the rest you just need a basic metric socket set.
I dont find it particularly tricky to be fair and if you have done a clutch then you should find it ok,
As for anything else, depends how far you want to go, if you have the head off could be worth doing the valve stem oil seals, the timing belt obviously and treat it to a thermostat and waterpump since its drained down.
MK1 1990 16v GOLF GTI CABBIE
ifoil on dipstick has mayo then its hg, if just cap its probably not!
if you are loosing water out of header rtank cap, replace the cap before you do anything else. also check the coolant flange on the front and side of head, these are common spots for leaks on old engines. also check the rad all over, any crusty white deposits point to a leak.
kai
