head gasket gone
(In Topic #129006)
head gasket gone
but just wondering how hard it will be and will the head need to be skimmed
______________________________
Golf mk1 1.8 gti cab (Still Working on it)
Merc E220
Merc E220
I would also buy new bolts and make sure you pay extra attention to getting the correct torque level on each one in the correct order.
If you do end up getting your head skimmed then make sure you get the correct thickness of head gasket, sometimes refered to as repair gaskets.
06 Audi A3 (Wifes daily)
But as if by some luck the gearbox gave out on the works van and the recovery just happened to be very knowledgable of the engine and said if i am not going to get to it straight away to drain the oil out of the sump put the plug back in and then fill it with desiel so as to stop the pistons rusting in, so think i might do this so that i can concentrate on the body once again so that i can get it off to paint and do the enginge while it is away.
Merc E220
Merc E220
the classic white cream over the filler cap
the empty header tank
and the sound of a vacum right as i realised it had done it
Merc E220
Merc E220
There are some real idiots out there and I've proven in the past that I'm one of them!
also cream on cap has cleared have a feeling that i has had cheap crap oil in it and the moisture in it has burned off slowly
although stil gotta open the enginge anyway as it is knocking like mad :dontknow:
but time will tell
Merc E220
Merc E220
