GTI won?t run?? Help please...
(In Topic #95313)
Hi guys, just got an 1800 GTI need some help its been off the road for 6 years and have tried to get her going problem is it fires up and almost runs but then just stalls? I tried taking the cold start valve connector off and it doesn?t even fire up so I assume its running of the cold start valve fuel for a few seconds and is not getting fuel to the plugs vie injectors?
Knowing this I checked the inlet for fuel into the metering head sprays out at pressure as I unscrewed it assuming its getting enough pressure from the pump and I bought a new pump so I can?t see it?s the pressure.
Tried a second hand metering head and didn?t make a difference as I though it may be this.
So I tried unscrewing an injector and putting the fuel pump on and fuel did come out of the braded line where it would connect to the injector as I pulled the metering head plate up. However it was not a jet of fuel but I assume the pressure builds up to 3.0 car allowing the injectors to then open.
What can it be, injectors?? Or fuel pump cutting out when it?s been turned over? Is there anything else it can possibly be its beaten me I have no idea?
Cheers any help would be brilliant
Mark 1 Golf GTI 1982 1.6 owner!
Mark 2 Golf GTI 1986 owner!
once you lift the pressure plate by the metering head, you should get a steady + even spray pattern coming out of the injector nozzle
I'd start with replacing any leaking lines, then take all 4 injector's out and check they're spray pattern
If your still getting nothing I'd say you've got blocked injectors
HTH
I tired the same thing with the injectors on and nothing came out of the injectors? what can it be other than the injectors, fuel pressure?
have you drained the tank and used fresh fuel? 6 yr old petrol is not too good.
Campaign Mk 1 Black
16v Mk2 Red (decsd )
