GTI Starting / Running probs
(In Topic #94372)
Badly behaved GTI cab
Sticking fuel pump non-return valve.
Fuel pump relay on the way out.
Fuel pump on the way out.
Incorrect delivery pressures [metering head]
I have listed these in order of expense. The first three are simple jobs for the moderately mechanically capable. The metering head has a delivery pressure valve on the side & this can also be serviced by any competant amateur - beware of the shims under the spring! However, as far as dabbling with the metering head is concerned - forget it! Restrict your efforts in this area to checking the free-movement of the central plunger which is activated by the air-mass plate [aka The Frying Pan]
At a [genuine] mileage of around 150,000 these problems would not be unusual I hope that this is of some use
golf gti starting/running problems
