gti DX engine
(In Topic #124110)
gti DX engine
only the bottom half off mine has gone, or failing that which bottom ends match my cyl
head which is spot on.
Thanks for your help
dx engine wanted
Regards
an ev would be fine. just need to use the mk1 manifolds.
If I were selling an engine and someone was unsure etc, I'd give them a bit of time but after a while just chuck it on eBay, so don't hang around, just go for the engine from GTIMAD!!!!!!
By the way in which way is the bottom end gone, and if its a bearing broken up then you'll need to carefully wash out the head of all old oil/metal particles, eg send it off to get it chemically cleaned and head skimmed/checked etc. The same guys who skim heads will know what's needed and be quite happy to also clean it up, etc.
me head is a bit bettered .Only the car is set in the garden having had s@ T loads off money spent on it . I want to make sure on whats what
Regards
piston rings are like razor blades and bearings are gone a friend off mine stripped it down
and said its cheaper to buy a secound hand engine. i just want to get on the road only its been 2 years
in the making .Regards Richie
thinking all was ok till i ran the car around the block and it overheated bought new pump, new water pipe,but damage was already done
so its this year or it gets broken and i start over with a G wagen. Regards
Member 125 - 2005
DX engine code
Regards Richie
so thanks once again Richie
