GOLF WILL NOT START WHEN HOT
(In Topic #75866)
CLEANED AND REFITTED FUEL INJECTION STUFF AS IT WAS.
TUNED UP BY EAR FOR NOW AS RUNNING IN BEFORE TUNING IT PROPELLY.
CAR STARTS FIRST TIME WHEN COLD BUT ONCE WARM YOU HAVE TO PUMP THROTLE LIKE MAD FOR ABOUT A MINUTE AND HOPE IT WILL START BEFORE BATTERY RUNS OUT.
PLEASE HELP AS THIS IS NOT COOL AT PETRAL STATIONS.
PS .CAR DOES NOT OVER HEAT
PPS .ANY RECORMENDED TUNNING PLACES IN BIRMINGHAM OR MIDLANDS AREA.
1983 lhasa green mk1 1.8 gti
old skool baby
old skool baby
hot start problem
NO SMELLS OF PETRAL OR LEAKS FROM INJECTORS.
IS THE COLD START VALVE THE ONE WITH TWO FUEL PIPES ON FRONT OF BLOCK OR THE SINGLE PIPE ON THE INLET MANIFOLD.
old skool baby
old skool baby
The two pipes on the front of the block are the warm up reg. loads of posts on that elsewhere.
I get that knocking too, always put it down to residual pressures in the pipes, had it for a year and no problems yet!
Peter.
1980 1600 GTI, daily driver.
Any way i brought a new pump ?87 nice and quite and no thumping after turn off AND YES IT STARTS FIRST TIME ,EVERY TIME HOT ,COLD ,WET AND DRY WELL CHUFFED.
Thanks to everyones help i have learned alot about the fuel injection stuff in the last few weeks. it's amazing how many things can go wrong for one problem. I would like to give some advice for anyone with the same problem and thats follow the component cheaks in the manuel which are farily simple once you have red them about ten times. If that fails hope the car brakes down with the problem you are looking for or start replacing stuff with the cheapest stuff first.
old skool baby
old skool baby
