getting her running
(In Topic #92643)
getting her running
i have recently aquired a 83 mk1 gti 1800 cab, and i could use alittle help
ive replacd the fuel pump, ignition coil, dizzy, all filters and fluids.we have spark, compression and air…..and fuel…sort of
now, when i turn the ignition on, the tach goes to 1100rpm and when you try to start it goes up to 1500rpm (engine not running obviously) and only turns the starter motor when the screwdriver is placed on it
then i noticed fuel dripping from the pump, so i replaced the copper o rings, but still drips a tiny amount.
i thought ithen it was going to be a blockage so i undone the fuel hoses next to the airbox and let bubbly petrol out (trapped air i guessed)
still nothing
really want to get it running and mot'd, any help peoplewould be appreciated
scott
thanks
scott
so…5 wires
1 earth from bulkhead
2 (one black, one red/black)
2 (one black, one green)
also i guess its 1, 3, 2, 4 firing order??
indicators work, as does horn….wipers not so
maybe they're from the same loom as the starter/ig coil??
theres always the possibility of a immobiliser? can't seem find one mind
Then you know its a fuel problem if it starts.The tacho does suggest earth problem,but if no star after above maybe HT prob(coil,leads,connections etc)
Lets know how you get on and if you need any more help bud
Scrotty said
im certain its the ig wiring
so…5 wires
thought it was 1342, but i'm not sober just yet.
once iv gone over as much as i can, ill give her another go at starting and with any luck, i might have her ready for the mot by the weekend
if not, prepare for the barrage of questions
oh and one more thing
DO NOT USE A SCREWDRIVER ON THE STARTER MOTOR WHILE YOU HAVE FUEL LEAKING!
lol good ideawooders said
ok i'm sober now. 1342 firing order!
im only just getting round to her now, had alot on.
think shes gona have to go up for sale soon as my times going to be taken up with my new business.must get her running or ill get peanuts for her
**walks off into the cold, armed with a little faith and some spanners**
hth
