g60 info!!!!! need help please
(In Topic #127561)
Im quite new to all of this and so to some it may seem like obvious question/answers but to me everything will be a huge help. Im getting my mk1 at the end of the month, i want to drop a G60 into it. Could someone please give me some information please…….. :dontknow:
1- what ecu would i need?
2- how do i make a new wiring loom?
3- would i have to uprate the brakes and suspension?
4- where can i buy the items to make a new wiring loom?
5- could i use the mk1's gearbox or would i have to change that along with the clutch for the G60's.
Any help would be fantastic
Member 125 - 2005
these are a few bits i can think of that you'll need ( please add if i miss anything )
……..g60 engine , charger, ecu ,
mk1 loom and g60 loom mated into one ,
driverside engine mount ,
gearbox mounts,
100mm driveshafts,
g60 gearbox, some recomend a mk3 diesel , ???
intercooler,
pipework for intercooler,
clutch conversion kit - hydraulic to cable, unless you choose to keep hydaulic set up ,
cable change gear selecter,
i'm doing this aswell, i plan to upgrade my brakes as suspension , but will do that as funds allow …..
