FUELLING PROBLEM HELP NEEDED
(In Topic #77695)
any ideas would be welcome
many thanks Paul
cheers Paul
Undo the 3 short screws and remove the round plate, then disconnect the rubber fuel pipes. Turn the white plastic flange anti clockwise and the unit should come out in one, you may have to twist it slightly to get it out.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=8184 :dontknow:
Also see if you can tell which pump is buzzing.
Cheers,
Ross
