Fuel pump keeps going
(In Topic #156514)
any help on this would be much appreciated. When I turn the engine off, 1.8 dx injection, the fuel pumps keep going. They will only stop when I remove the relay 19. I,ve tried changing the relay but still does it. Engine has been out for a year and refurbed but had this problem before.
further to this message, now realised fuel pump relay is 62, and has not been replaced, could this be at fault. Had a look behind fuse box and there's a number of fresh wires been put in, so someone's had fun in the past!
maybe take the lid off your 62 relay once the 18 is in it, see if the contacts can be cleaned or anything. also check fusebox for corrosion, if its bad replace it
