fuel pump fittings
(In Topic #112616)
fuel pump fittings
I've had to get a new pump and the brackets that hold it in place, and the metal pipe that goes from the pump to the accumalator.
I have been under the car and cannot for the life of me see any mounting points for the bracket and accumalator. I cant see a way of getting it all to fit
The car is a 1992 gti cabby.
Has anyone any pics or diagrams of where things should be located. I've not got a Haynes yet.
Can anyone even give me some written help please.
Any help at all appreciated as I'm waiting to fit it all together.
Do you know where about does the pump fit and where does the accumalator fit?
the accumulator is next to the fuel tank, it kinda a 90 degree angle. hard to explain! you should have holes on the chassis somewhere for the brackets to fit too, there are Z shaped brackets that bolt to the chassis, then you have rubber mounts, and then the brackets that hold the pump/accumulator. There was a post around here somewhere…
what do you mean by seat hump?
