fuel problem? mk1 golf convertable
(In Topic #136970)
James
ok james thanks. new user hopefully i can get sum help there then after reading some of these posts i think i know where this is leading to.Spudfingers said
This is a mk1 technical big block injection question not general chat. Moved to "Big Block Injection Engine" section so that the technically minded amongst us can help you. Thanks,
James
Have you checked ya fuel tank and fuel filler neck for rust / corrosion.
They often rust then small bits of rust get into fuel lines and fuel system and can cause troubles.
If you search there is a thread on here showing how to get to the fuel tank inspection chamber underneath your rear seats where you can look in (with the aid of a tourch) and see if there is much rust in ya tank
hope that might help …. Rich
1.8T CABBY
1.8T CABBY
