Fuel pressure problem ??? Need help !
(In Topic #143307)
I chek the mark and replace the timing belt , timing ignition , new plugs, new coil, new cap rotor , chek the injectors spray , New fuel hose , test 1 wur and 1 fuel distributor from a friend , test the fuel pump fluid delivery … If i plug the wur the car is a bit worst ! Im now running with the wur unplug! Should it be the injector seal or something erong with my fuel pressure ? Car run rough and rich with the wur plug , if i ajust the idle mixture the car idle perfectly but i have the same problem no power in first gear under 2000rpm !
http://www.race.nangreaves.com/golf/index.htm
