Fast running
(In Topic #122882)
Fast running
Thanks in advance
When the engine is cold, there are a couple of things that that happen to help the engine run at a reasonable speed. It could be that these are not working properly. They should operate only temporarily during warm-up of the engine, it could be that they are continuing to work even when the engine gets warm, or it could be that they aren't working at all - and to compensate, the tuning of the engine has been fiddled to allow the engine to run even when cold.
If the timing, throttle screw etc. are set-up correctly, you might want to check the throttle bypass valve, which should be open when the engine is cold, and should gradually close as the engine runs. The control pressure regulator could also be faulty?
good luck
So It has been sat for a while and maybe just needed a decent run.
Might not be this but definately worth a check!
MK1 GTi Cab '91' H Black
Mars Red Campaign - work in progress
MK1 GTi Sportline '92' J Red
