Exhaust manifold stud removal
(In Topic #219379)
Just checking if there’s a tool I can use to remove the exhaust studs as two have dodgy threads and won’t tighten. Thanks
I have used a Stud remover in the past, but if the manifold is in your way, it may not work.
I have also used heat and a pair of vice grips low on the stud separated by a washer…..
If you look up a 1990 saturn sl1 they have SS studs that have a allen or 1/4" drive end that makes putting them in and getting them tight Very easy.
Slather everything with Never-seize. and use the copper nuts.
It really is quite a simple procedure, as demonstrated in this video:
Can You Get Out A Broken Bolt With Wax!? - YouTube
