engine whine linked to rpm
(In Topic #150523)
I have been having a problem with a whining noise coming from the engine bay. I believe its coming from around the fan belt.
The noise gets louder in line with the engine rpm, when in gear or out of gear. The water pump was only changed around 18 months ago . Ive changed the V belt and also stripped down the alternator and changed the bearings but to no avail. Has anyone any more ideas?
Ive read on here the cam belt tension pully could be at fault? Is there a way to check this before messing around with the belt?
Cheers, Cav
1983 VW Golf 1.8 GTi
2008 VW Golf GT TDI 170
cav1989 said
Evening all,
Cheers, Cav
Hi
had similar problem on mine turned out to be the bottom pulley rubbing on the cambelt cover, managed to realign cover and sort it
Dave
that way you'll know if its located cam or fan belt side.
check both belt tensions or possibly the cambelt tensioner is noisy.
here for a good time, not a long time
A couple of years ago, there was a lot of talk about non-genuine cambelt tensioners whining. Don't know if it's still an issue, or indeed when yours was changed! Brand new ones were doing it - not a sign of failure, just an annoying noise!
