engine running to fast
(In Topic #102288)
The idle adjustment screw is on the rear of the throttle body (thats the part where the accelerator cable attaches), feel round the back and you'll find a 7mm bolt. Get the engine hot then try adjusting the idle screw, turn it in to increase the revs or vice versa, if that fails to bring it down then it maybe the auxillary air valve (this is situated at the rear left hand side of the inlet manifold) at fault. To check if it is the AAV look to the left of the inlet manifold and you should see a rubber hose that goes that goes round to the rear of the manifold, squeeze it with some pliers…..if the revs drop then look at getting a replacement AAV.
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
