Engine rebuild
(In Topic #73355)
Engine rebuild
Just finished rebuilding the engine in my Y reg golf 1600, after replacing all the bearings, gaskets and piston rings using rings from euro parts I went to start the car up and it did not start. So checked the basics fuel and spark. And then done acompression check. No compression at all valve clearence ok head all torqued down,timing ok. somehow recon its the rings but did check the free gap was ok. Anyone have any ideas or passed experience. :dontknow:
Craig
Check the cam timing is setup correctly.
Put a teaspoon of oil down each bore and do your compression check again. If you get a little compression then suspect the rings.
let us know how you get on.
Engine rebuild
So now I have decided to buy the origanl rings from vw.
But there on back order so have to wait a few weeks.
seems every part for the mk1's are either back order or obsolete.
Make sure you have eliminated other issues like valve seating and timing. If the valves are not seating properly - only needs to be a small amount you will get poor compression (likely to be worse on ony one cyl though). Valve timing could be way out - again check the timing before you rip the engine apart.
Engine rebuild
Only thing I can think is the piston rings are the wrong type
did notice new piston ring are stepped instead of flat would this make a diffrents, also have heard there are diffrent pistons K.S and mahle according to haynes manual maybe these have diffrent ring thickness.
Also when you put the new rings in, was the block rebored or given a light hone to help bed the new rings in?
Engine rebuild
Rings are not normally an issue unless they are completely the wrong size - thickness should be less of an issue
If the rings are 'wrong' and not sealing, presumably they'd allow oil past which would foul the spark plugs, so might be worth seeing if that's the case first. The rings would have to be a really poor fit for the car not to fire at all IMO. More likely a timing problem as Crazyquiff said. Is it noisy when you turn the engine over ? Are you using fresh plugs ?
Good luck with it,
Mark
Engine rebuild
Then lined up the bottom pulley with the mark on timing cover. I als lined the top end up so both number one cam lobes are up and lined the mark up on the sprocket.
Have now taken the head off valves o.k(not bent)and took one of the pistons out.
Did notice that the top two rings seem a bit loose and slide left to right just by tilting the piston, is this right. :dontknow:
There is also no oil coming up past the piston.
Did you use a ring compressor when you fitted the pistons to the block?
I'm a bit stumped on this one - even really badly worn/broken rings would give you about 20psi on a compression test. That's why I keep on about valves etc
