engine not reving properly
(In Topic #80917)
Does the car rev freely in nuteral? All other guages normal (temp etc)?
Check for obvious stuff first
Throttle cable is tight and hasn't come loose
Check HT leads are in good nick, no cracked/damaged
check dizzy cap has good contacts/good order
Check all engine earths, the one under the battery attached to an engine mount is a particular one prone to rusting
So many dubs so little time, so much rust
